Kemore Oven
Old 02-04-01, 03:55 PM
Guest
Smile
Just to let you know that, with your help, I found and fixed the problem with my oven. I found out that it requires approximately 1.5 to 2 amps resistance to cause the gas vale to open. This is with the Carborumdum type ignitor and only after it is hot. I traced each wire from start to end and found a partially broken wire that would disconnect with heat. After replacing the wires, it worked as good as new.
Thanks,
Bigbyrd
Old 02-04-01, 05:07 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
ATTA Boy For Me?
Hello:Bigbyrd
Glad to know you found the problem, got it corrected and also took the time to reply back. Thanks!
Ever need help with a gas appliance, post it here and I hope I can help you fix that too.
Have any other questions on other subjects, visit the other forums on this site and get helpful advice, suggestions and tips from the moderators in those forums.
Have a helpful hint-tip or trick? Post it in the Hints-Tips and Tricks forum and share with us. Reply in any forum if you have the time, subject knowledge or expertise to help others. Be glad to have you join in.
Oh Yeah!...Thanks also for the ATTA Boy! I needed it...haha...
