Blanco gas cooktop with electric ignition
Received 0 Votes
I have a blanco gas cooktop with electic ignition, I press and turn the knob to light but nothing happens no clicking and i cant smell any gas , It was working yesterday .The gas hot water is working so gas it getting into the house. Electricity is working on other appliances. Does any one have any ideas as to what is going on or what i may be doing wrong. Thanks
Welcome to the forums from down under.
I can't find much service info on Blanco products. I've found parts centers and the controls look similar to the ones used here. They appear to use separate switches on the gas valves for the spark ignition which means that even if the spark system was not working you would still get gas.
So based on that I can't tell you why you don't get spark or gas. You may have to contact Blanco service directly in Au.
Received 0 Votes
sorry I do get gas, i couldnot smell it but once i put a match near the burner i got fire. so now it appears the electric ignition is my problem which i need to buy and replace. Thanks. Gazzah
You should check with a voltmeter at the spark module to see if you're getting your mains voltage to it. Turn on a gas valve and the voltage should appear on the spark module. If it does.....the module is bad and must be replaced.
