Natural Gas to LP Grill Conversion
Hi there. First of all let me apologize for posting this here. Finding the right place to post a grill question ended up being more difficult than I intended. Anyways, my brother in law recently bought a new grill and asked if I wanted his old one. Since I have always used charcoal and this was a nice gas grill I accepted. What I didn't know was that it is a natural gas grill, not propane as I assumed. It is a Kenmore Elite Natural Gas Grill Model #141.157951. Now after a bit of web searching I have learned that I basically have two options. Convert the grill to propane or run a line out to the grill. While I am capable of most basic tasks I am certainly no Super Handyman. Which of these options is the most realistic? Thanks for any help which will be greatly appreciated.
Welcome to the forums.
We have moved your post to a more suitable location.
I know which I option I'd prefer since it's exactly what I did. I ran a natural gas line to my BBQ location.
The choice is yours. If you convert to propane you may need to purchase some internal gas metering parts as well as a new line set and propane tank regulator.
Thanks for moving my post. I was hoping it would be directed to a better location. I can't believe I missed this category though.
I thought that converting it did sound a bit complex. How big of a job is it to run a gas line if you dont mind me asking.
I don't mind but it can be a little difficult to answer since I don't know where your gas lines are now or where you need to run them to.
Many plumbers are using a flexible supply line called CSST (corrugated stainless steel tubing). It's more costly than black pipe but easier to run. I opted to run black iron pipe as that is a medium that I am familiar with. I was able to tee off of an existing 1" gas line that fed the furnace and water heater.
I ran 1/2" pipe about 20' to a quick release fitting on the outside of the house.
