Kenmore Wall Oven wont heat up to desired temp.
Old 06-27-13, 02:36 PM
D
Exclamation Kenmore Wall Oven wont heat up to desired temp.
I posted a couple of days ago, but didnt have the product number, and now i cant find that post so im re-posting with the product number.. sorry . My issue is, my oven turns on just fine, ignites, but only stays on for 1-3 minutes before saying its reached the temperature i put it in, and it doesnt even get close. The product number is 911.3012990. Im desperate to have an oven that works, so I can stop having to use the microwave and have soggy tasteless food! Plz Help!
Old 06-27-13, 09:16 PM
Received 3,897 Upvotes on 3,494 Posts
You couldn't find your post because it was in the electric appliance forum
No problem......good to see you back.
As to the answer I left you in that other thread.....the temperature sensor would appear to be defective. It could also be a wiring problem to that sensor although that is less likely. Normally I would say just replace the sensor but for this oven it appears to be unreasonably expensive.
The FSP #WB21X5301 can be used to shop for the sensor. You can also check with a local appliance parts place where they could even check your old one for you.
In the link below is one place that carries the part. The also have a video there to show you how to test it.
Oven Sensor WB21X5301 Order now for same day shipping. 365 day return policy. Repair Clinic
