kenmore series 70 dryer conversion to natural gas
Old 02-13-01, 01:41 PM
Guest
I have moved from an area that had propane to an area that has natural gas.. I need to know how to convert .I have the kit........and i converted it from nat.gas to propane 6 years ago..but i cant remember if there are 2 brass fittings to change or 1..plz help..i am wearing wet clothes ..ps i got dryer to fire up..i chaged one valve leading into the gas supply on bottom ..but its not burning hot enough..thanx
Old 02-15-01, 08:08 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hi:wearingwetclothes
To convert back to natural gas, you'll need to install the brass orifice with the larger hole.
If you have done the conversion prior, you're most likely aware of the other steps required. Whatever you're referring to as the valve "on bottom" is a mystery to me.
Since you already have the conversion kit, the rest is explained in the instructions.
