How to replace gas burner on Magic Chef stove
Old 10-02-13, 09:07 AM
I have a need to replace front right burner on Magic Chef Stove (Model #CGR1420BDM).
It is corroded on one side so that the gas comes through unevenly and the igniter is broken off.
I think I have found a replacement part easy enough. It is not clear how to remove the old burner. Do I just use a pair of large Channel Lock pliers or pipe wrench? I don't want to damage the connecting pipe under the stove lid trying to remove it.
Do I need any sealant for the new part?
How does the ignitor connect to electrical source?
Thank you!!
Old 10-02-13, 02:23 PM
OK, I got a replacement part, twisted out the old burner, disconnected and reconnected the ignitor wires and now none of the ignitors work?!? Any suggestions?
They all worked except for the one I replaced before I put in new burner. I tried reconnecting the old one and still none of the ignitors work at all. I reconnected it exactly as it was from the factory since the connector clips are two different sizes so you can't reverse the wires.
Thank you!
