Help Maytag Gas Oven F3 but already changed out Temp Sensor
Old 10-20-13, 08:45 AM
R
I have a Maytag Gas Oven that was showing a F3 error code So I replaced the Temperature Senor seemed to work OK Then I got a F5 Code one time and since then the Oven will heat up and cook but then the F3 Comes up again.
I am wondering if I am missing something I am on the verge of having to replace the Whole Oven if I can not come up with the next thing to do.
Oven is about 6 years Maytag Oven CWG3600AAB Worked perfect for 6 years
Any comments
Old 10-20-13, 09:26 AM
Received 1,483 Votes on 1,371 Posts
Welcome to the forums.
You could possibly have an intermittent connection in that jack where the temp sensor plugs in or at the clock control board.
I'll usually access the clock control area and check the temp sensor wiring at that point while moving the wires and connector around.
