slight gas smell
Old 02-23-01, 09:16 PM
Guest
Exclamation
Every once in a while when I walk past my gas stove I can smell a slight gas odor. Is this a problem? If so, how do I fix it?
Old 02-23-01, 09:32 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Soap It
Hi:anything
Without knowing more about the stove you have, I would say you can find that tiny leak with plain dish soap. Just mix up some ordinary liquid dish soap with water in a cup.
Make the soapy water mix kind of heavier with soap and mix it up until it foams. Use an ordinary walltrim painting brush and apply the soap to both ends of the flexable connector. Tiny bubbles should begin to appear after a short time.
A smal leak could be found at any fitting where gas passes through. Check all tubing nuts too. Be patient. Tiny leaks may take a few minutes to appear.
Be sure to apply soap to the undersides of each location tested. Some leaks are on the undersides of fittings and may not always be easy to see.
There may also be more then just one tiny leak. Soap test as many locations as possible. be sure to unplug the stove prior to soaping.
You may also just have a pilot out somewhere. Check for that prior to soap testing.
