Tappan Oven Popping Noise
Old 01-12-14, 04:05 PM
B
Hello,
Recently, while using the broiler on my Tappan oven, I heard a loud "popping noise". The oven shut off and the power went out in a few rooms in the house.
I reset the circuit breaker for the kitchen and all the lights came back on in the house, however, the oven still does not work.
I tried using the stove top and only gas comes out but no flame.
The oven does not heat up and the stove top does not ignite.
Any help would be appreciated.
Thank you,
Ben
Old 01-12-14, 05:06 PM
Received 1,485 Votes on 1,373 Posts
Welcome to the forums.
That looks like a gas only range but the problem you're describing sounds like a combo gas/ electric range. Can you post the model number for it ?
Old 01-12-14, 05:58 PM
B
The number inside the oven door is 180-6C140 and the number in the back of the oven is 180-6C145. Not sure if these are the right ones to be looking at.
Thank you for reaching out.
Ben
Old 01-12-14, 06:18 PM
No....those are anti-tip sticker part numbers.
Pull out the drawer and look in the upper left corner.
Old 01-12-14, 07:01 PM
B
The model number is: MGF500PBWM
Old 01-12-14, 10:04 PM
Yours is a basic gas range. I don't see any protection devices listed in the parts list and I can't find a schematic for it. You're going to need check for 120vac at the receptacle and then inside where the power cord enters the unit. The popping sound may have been a wire shorting to the case of the appliance.
You may end up having to remove the back cover of the range to look for a problem.
