Gas dryer shut off problem
Old 12-24-14, 03:57 PM
D
I have a dryer that was connected to a small propane tank. Unfortunately, as things stand now, whenever I dry clothes I have to be around to physically shut off the gas when the dryer is done. Is there anything I can add to automate this?
Old 12-24-14, 04:00 PM
Received 3,898 Upvotes on 3,494 Posts
Welcome to the forums.
Where is the propane tank ?
It should be outside and there would be no need to shut it off.
Old 12-24-14, 04:14 PM
pugsl's Avatar
Received 77 Upvotes on 70 Posts
Post model # and what is happening. does the dryer shut off or does the flame keep going????
Old 12-24-14, 07:06 PM
D
GE Profile Harmony™ 7.3 Cu. Ft. Capacity King-size Electric Dryer with Stainless Steel Drum | DPGT750ECWW | GE Appliances
This is the dryer we have. We have our setup in a screened in porch area. The propane tank is probably a 30lb one so pretty small.
Pugsl: The problem seems to be that when the dryer has completed its cycle it doesn't have a way to shut off access to the tank and if left open long enough, the tank empties completely.
Old 12-24-14, 07:12 PM
D
Old 12-24-14, 08:33 PM
Propane has a very distinctive odor. Even a small quantity will leave a lasting smell. If you aren't smelling the propane then you must have a very small leak.
It's not the dryers job to turn the gas off. You need to check all the connections with soapy water to try and locate a leak.
It looks like you're using TinyPics. This site will not link to them.
http://www.doityourself.com/forum/el...rt-images.html
