Gas stove flame set too high
Old 03-08-15, 01:06 PM
Perhaps this is a crazy question but is there a way I can get my stove to a lower setting for simmering or cooking low? All burners are way too high.
In advance, thank you
Old 03-08-15, 01:29 PM
Received 1,473 Votes on 1,361 Posts
With most gas stoves you can pull off the control handle and there is a hollow tube with an adjustment at the end. Sometimes you can look in and see it.
Set the burner to low and using a small flat screwdriver turn the screw. I believe clockwise is lower. You shouldn't need to turn it much.
Old 03-08-15, 02:54 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
They also make heat dissipaters (kind of a perforated flat plate that goes between the burner and the pan) that can help with that. I had the same issue at my last place. Even on low I couldn't simmer a sauce w/o it boiling and scorching and there was no adjustment that I could find.
I'm so happy that this rental has a stove with different size burners, obvious by the size of the caps. 2 high, 1 med, 1 low. Works great.
Old 03-08-15, 03:14 PM
I agree... different size burners is ideal.
Sometimes the burners are set intentionally high so that they don't blow out on low flame.
Old 03-11-15, 06:02 PM
Thanks for the suggestion although we didn't have anything behind any of the handles. It would have been ideal though.
Old 03-11-15, 06:06 PM
If you pull the handle off..... look above or below the control shaft.... you may see the adjustment screw there instead.
If not.... post the model number so I can look up the valves it uses.
(center of shaft adjustment)
Thanks I'll check for the plates!
