Fixing up an old grill
Old 03-17-15, 05:42 PM
R
So I just got a gas grill that is going to need a lot of fixing up. I plan to replace the tubes and plates, but I'm a bit stuck on one part. In the attached picture with the arrow, you can see that each tube burner should be resting on a ledge that was attached the main part of the grill. The second attachment includes the ledge (and all the rust and other stuff). It has basically crumbled, so the new burners don't have anything to keep them level. Any suggestions that wouldn't cost too much?
Name:  Photo Mar 17, 6 39 12 PM.jpg
Name:  Photo Mar 17, 6 39 38 PM.jpg
Old 03-17-15, 05:46 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Welcome to the forums. I had a similar problem and bought a piece of steel angle and bolted it in place to create the ledge, leg down/leg out.
Old 03-17-15, 05:50 PM
R
Thanks. I'm looking for all stainless steel here, or does it really matter?
Old 03-18-15, 03:17 AM
chandler's Avatar
For the projected life of a grill, no. Stainless is expensive and steel will last as long as the grill will, most likely. Mine has been going for 3 years and I cook on it quite a bit.
Old 03-18-15, 05:29 AM
czizzi's Avatar
Many of the replacement burners have feet already attached to them. When I did not retrofit, I splurged for a all brass burner so I would not have to change it out again.
Old 03-18-15, 05:35 AM
P
Received 1,951 Upvotes on 1,747 Posts
Luckily I have a machine shop with a nice pile of scrap stainless steel lying around so I just scrounge and look for something appropriate. You could check with local welding or steel fabrication shops to see if they will allow you to pick through their scrap bin. If you catch them in a good mood and offer to pay they'll often let you take what you want for free.
Old 03-18-15, 01:02 PM
chandler's Avatar
Actually the bar I replaced, so I discovered, held up the flame preventers as shown in the picture. I see, now, my burners are going south, so I have to decide on 3 burners, flame preventers, and other repairs, OR a new grill. Which is cheaper?
Old 03-18-15, 07:26 PM
R
That's about what mine looks like. Based on what I've seen online, I still think it would be cheaper to replace the parts.
