Pilot light for the oven not igniting
Old 07-09-15, 08:35 PM
T
We have a GE gas Stove/Oven. The oven is not working. It is not heating up.
After researching on the internet it seems that the reason is the ignition element is not in working order.
The stove top is still working but the pilot light for the oven is out and will not relight.
In most cases the reason the pilot light for the oven not igniting is because the ignition elements are out and need to be replaced.
Who had this issue and can help fix it?
Thank you
Old 07-09-15, 10:14 PM
Received 1,399 Votes on 1,296 Posts
They haven't used pilot lights in ovens in many years.
Most ovens use a ceramic igniter that glows bright red to light the gas.
If you post the GE model number for your range I can give you further detailed information.
Old 07-09-15, 11:01 PM
T
Old 07-09-15, 11:19 PM
The XL 44 is just a GE trade name. Look for the ID plate down the bottom if you have a pull out drawer or in the oven doorway.
The owners manual won't help me.
You do have a glow type igniter in your oven. I found the following video to be helpful.
you tube/watch?v=780-xxzLkuM
Old 07-09-15, 11:56 PM
T
Thanks for the link.
I already saw this and some other videos
https://www.youtube.com/watch?v=EH4jgIlaT60
https://www.youtube.com/watch?v=SQi3NtW70EY
The igniter should be replaced. Do you know the part number of the igniter for XL44?
I found this:
http://www.appliancepartspros.com/se...odel=ge%20xl44
Old 07-13-15, 10:45 AM
T
The model number GE XL 44 - JGBP28DED2WH
Old 07-13-15, 09:09 PM
The OEM part number for your igniter is WB2X9154
You can search for that part number and you'll find many places that sell it.
Be careful when installing..... it is a very fragile part and will crack easily if dropped, hit or struck.
Old 07-15-15, 07:13 PM
A
Would this be same igniter part number for my stove too??
Old 07-15-15, 11:33 PM
Did you get any trouble codes on the oven control board ?
