All 4 stove tops and oven not working
Received 0 Votes
1 year old propane oven just stopped working, plenty of gas outside, regulator seems ok, I am stumped!
My first check would be to see if get is getting to stove. That would narrow it down to a stove problem or something with the gas piping and regulator for the home. Don't forget silly obvious things like making sure the valve on the tank or a shutoff valve somewhere are not closed.
Received 5 Votes
Hello Robbuschor and Welcome to the Do It Yourself Web Site and the Gas Appliances topic.
Just a thought. Anyone clean under the top lid or elsewhere? Rare but possible an isolation gas valve turned off under stove top and or behind appliance? Move it, fix it or relocate it? New kitchen flooring installed then stove moved back to it's location and shut off valve not turned on?
If there are other or another propane gas appliance (dryer and/or water heater???) without the same problem, likely the condition only applies to stove. Kindly add more specifics and details. Not much info in first post. Help us help you....
Received 0 Votes
More info
Thanks much here's my attempt to be clearer,
Only the stove is hooked up to gas, line is going directly to tank I'm struggling to find model number on this ikea stove. The stove top s click but I can not light burners with a match so no gas is getting there.
