Oven emits gas smell only when maintaing set temperature
Old 07-21-15, 01:32 PM
Oven emits gas smell only when maintaining set temperature
Our Electrolux Range works properly when getting up to set temperature. Once that temperature is reached, however, we will intermittently smell gas. It seems that when the oven kicks back on to maintain temp, the gas will not immediately ignite each time. This problem is infrequent, but worrisome nonetheless.
Any help or advice would be appreciated.
Old 07-22-15, 12:08 AM
Received 1,404 Votes on 1,299 Posts
Welcome to the forums.
I would try replacing the igniter. It's the most likeliest cause of your problem. If not...always good to have as a spare.
I can give you more information if you post the model number for your appliance.
