Flames coming out the Range knob
Old 08-14-15, 02:45 PM
Hi!
I have a GE gas range model # JT20W0F3WW, when I try to turn on one of my burners it never turned on and instead a flame was coming out of the knob. I cut the electricity off and since then I am lighting the burners on manually with matches. Any idea what the problem may be?
Thank you!
Old 08-19-15, 01:29 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Based only upon the limited info provided, as I am able to understand it, not able to diagnose any condition or determine a problem. Slightly confusing. Burner never turned on (assumption not lighted by spark ignition) but able to light with match???
Old 08-19-15, 11:27 PM
Received 1,406 Votes on 1,301 Posts
When you tried to turn the burner on...... did you hear the igniter sparking ?
There is a switch on every burner knob that activates the spark module. You may have a bad switch. You would need to lift the stove top to look further.
