Old Roper gas range, burners and oven light intermitently
Old 09-16-15, 03:33 PM
Z
Unhappy Old Roper gas range, burners and oven light intermitently
I have an old Roper gas range and the burners and the oven are now lighting (or not lighting) intermittently.
Usually when the burners do not light, they all do not light. The oven can be lighting and sometimes it does also does not light. However it has never happen that the oven would not work and the burners do.
Finally I have noticed that the flame is not completely blue (orange flames).
Anything I can do about it. Otherwise the stove heats fine (if you light it with a match) and I would ate to have to throw it away.
Thanks
Old 09-16-15, 06:01 PM
Received 1,421 Votes on 1,314 Posts
Welcome to the forums.
You had posted your question in another thread and I replied there.
This will be your thread here.
Those are separate systems and one doesn't usually affect the other unless it's a gas issue.
Is your stove running on natural gas or propane ?
Are there pilot lights on the stove top burners and in the oven ?
Old 09-19-15, 05:13 AM
Z
Thanks. First, it is an old Roper 133. It is running on whatever gas comes from the gas lines in Baltimore
Not sure if there are pilot lights...
I know, not very helpful
Old 09-20-15, 05:04 PM
Z
Upon inspection - there are no pilot lights - it is pilotless ignition.
Please see photo
Attachment 56348
Old 09-20-15, 05:08 PM
Z
Roper gas range photo
Here is another attempt to post the photo
Old 09-21-15, 06:40 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: Zhena
Not lighting? Kindly explain how! Sparkers work? Yes or No? If the sparkers do not spark and is the reason the burners do not light, that's one problem. If the sparkers do spark but burners do not always light that's another problem. That model is sensitive to fuel and air mixture ratios.
"It is running on whatever gas comes from the gas lines in Baltimore."
The gas you're using is natural gas, not propane if gas supplied from and thru the gas company lines. Natural gas density does at times verify slightly.
If sparkers are working and burners at times fail to ignite, slightly close the air shutters on the burner tubes of the top burners first. Note the differences. Slightly richer fuel mixture ignites faster if done correctly.
BTW: Orange flames indicate the burning of dust in the air. Not a hazard nor unsafe.
