Pilotless Igniter Stove does not click or light
Received 0 Votes
As part of an old co-op unit that I purchased, I got an old stove in the kitchen. It is an Eagle Pilotless Igniter stove. I have no idea how old it is, but it wouldn't surprise me if it is from the 1980s...
Anyway, since I am rarely home it's not a big deal and it worked fine for things like boiling water and heating up food. But yesterday, after I turned off the electricity in the apt to work on the electrical outlet, the stove no longer lit.
When I turn the knob, I hear the gas rushing, but the normal click is gone. I can put a match near the gas tube and the stove top does light up.
What could be wrong and what is the fix? Is this a sign of a potentially dangerous defect?
Perhaps I should just get a new stove.
Thank you.
Thank you.
Did you turn the electric back on ? The spark module needs power to spark.
If you did turn the power back on..... what does the oven do ?
Received 5 Votes
Hello: Chuck
Not a dangerous nor hazardous condition nor defective condition, etc.
Key problem description:
Power at outlet. Be sure plug firmly pressed into outlet. Possible internal appliance fuse, if there is one, fuse blown. Fuse should be located inside spark module under it cover. Plug appliance plug out then remove spark module cover, if there is one. If there is a fuse, not all models have fuses, replace fuse with an exact duplicate appliance fuse.
Kindly use the reply button to post all replies, add additional information when replies are posted. Using this method moves and/or keeps the topic back up to the top of the list of questions automatically and keeps all content on the same subject within one thread.
Received 0 Votes
Thank you! Yes the problem IS power. I verified that there is no power at the outlet.
Although I turn the power back on at the breaker box, I never tested the power at the kitchen because the kitchen light turned on. But on second thought the light and the outlets must be on different circuits.
As for the cause of power loss, I believe the cause may be this:
I was working on replacing a two-pronged old receptacle near the kitchen sink with a GFCI receptacle but am having problems with a loose wall box due to an overly large cut in the drywall that I need to figure out a way to secure first, so I had to stop after I cut the wires to the receptacle, pending additional work. I made a post here:
http://www.doityourself.com/forum/el...box-loose.html
This receptacle must be on the same circuit as the stove outlet, so cutting the wires there must have broken the circuit and caused this power outage.
Do you think this is it?
