Burner on Thermador PRG304 won't light - gas does not flow to burner
Hi,
We have a Thermador gas range, model PRG304. The front left burner which has an XLO setting stopped working when I turned the knob too fast one time. Now when I turn the nob, there is a spark, but there is no sound/hiss of gas, so no gas is flowing to the burner. We're trying to figure out what the problem could be and possibly fix it ourselves instead of getting hit with a high repair bill. Watching a video I found on YouTube, it seems like the problem may be the electronic board just behind the knob (relatively easy to figure out) or the gas valve (much more involved). We haven't tried switching the boards of the front and back burners to see if that solves the problem, but if that doesn't solve it, and before buying the valve (around $125), does anyone know if there could be another reason (some loose connection?) why gas is not flowing to the burner?
Thank you very much.
Is this a PRG304US model ?
Hopefully it's the little potentiometer board on the gas valve. You can swap two boards among burners to determine if it's bad. Chances are when you turned it hard you cracked it.
Here's a service bulletin in regards to replacing the pot boards.
updated/service/bulletin189816.pdf
Thanks PJMax. Yes, it's the PRG304US model. Just to make sure I understand, you mention the little switch board on the gas valve. Are you talking about the 2 by 2 brown square electronic board just behind the knobs, or are you referring to something that sits with the gas valve which is deep down under the burners? Thanks so much.
