Kenmore gas dryer 110.7483200 no heat.
kenmore gas dryer 110.74832400. Ignitor not glowing at all. Ignitor show 72 ohms resistor which is standard. Flame Sensor shows continuity. solenoid coils are ok. Thermal Fuse is ok. Thermostat are ok, I removed the cable from igniter at gas valve and try to measure voltage but meter shows 0.00V. the front panel was removed but all circuit at that time was closed.
Should be 2 thermostats, a flame sensor, ignitor, thermo fuse all should have continuity.From timer to thermostat should have 120 volts. Trying to remember dryer it is pretty old. Haven't seen one of those in several years. Is there a wiring diagram glued to back? Solenoids should have a ohm reading but can't remember spec.
There should be a two prong plug that connects the power from the dryer to the gas valve/igniter area. That plug will be near the gas valve. The two wires it connects to get lost in the back of the dryer.
Check those two wires for 120v. If there.... the problem is at the gas valve/igniter area.
If the voltage is not there..... then it's not getting thru one of the limits or coming from the timer.
