KitchenAid Stove conversion to propane
Old 04-01-16, 09:40 AM
I just got a 15 year old commercial grade stove that has been in storage for 12 years. The problem is that I use propane. The regulator was easy to change. My problems is the orifices are no longer available through KitchenAid (or anybody else) and when I talk to appliance people they say that you really need the right ones for that stove. All of the burners have an output of 15,000 BTUs. I know the thread size from the natural gas ones that are in there. Don't I just have to find orifices with the right thread and then match up the hole size for 15,000 BTUs? Please let me know if I am missing something, I would really like to get this stove working but don't want to blow up the house in the process.
Mark
Old 04-01-16, 09:41 AM
Received 940 Votes on 877 Posts
Welcome to the forums.
A model number of the appliance would be a good place to start.
Old 04-01-16, 11:02 AM
Sorry about that. KitchenAid KDRP407HSS3. Part number for the conversion kit is/was 4455353.
Mark
Old 04-01-16, 11:15 AM
Handyone's Avatar
Obviously, you have searched the entire stove for the propane orifices?
They are sometimes in a packet or metal strip that is screwed somewhere into the rear area.
Old 04-01-16, 11:23 AM
I have searched the entire stove several times as the instruction book said that they should be taped to the back. I assume they were on the back at one time but not anymore. I have pulled off the front, the back, shined a flashlight in between the panels.
Old 04-01-16, 01:38 PM
I'm showing a different conversion kit. There may be several that will work your appliance.
Check with Appliance Parts Pros and see if this kit will work for you.
KitchenAid gas range for use with LP- kit - Appliance Parts Pros
