Restraining device for a gas appliance
Old 05-12-16, 09:15 AM
W
My question is about the necessity of installing a restraining cable when commercial gas appliance is connected with flexible gas connector but doesn't have casters.
According to some gas codes, a restraining device is required for all types of movable gas appliances when flexible gas connector is used. According to manufacturers of commercial gas appliances and the manufacturer of the flexible gas connector, restraining device should be used when the appliance has casters.
The appliance in question doesn't have casters, but it can be moved by the average person with relative ease. Is it still considered movable? And if not, should restraining cable still be installed?
Old 05-12-16, 10:11 AM
Handyone's Avatar
Since you said 'commercial', you will have to check with the city and maybe the gas company.
I've worked on residential kitchens for 15 years and consider any range, standard or professional quality, movable (with or without casters). So this restraining cable must apply to commercial applications only.
Old 05-12-16, 06:51 PM
Received 1,108 Votes on 1,028 Posts
You're right.... I believe the code says if the stove has casters then a tether is required.
However, I'm seeing inspectors require a tether on any flexible gas line connected stove that can be moved.... period.
This is strictly commercial applications..... not in a home.
Old 05-13-16, 03:14 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
In our area there is no distinction between having castors or not.
The idea is even without casters a flex line would allow you to move the appliance for cleaning and stress the hose if not tethered.
