Replacement BBQ Grill / Grid?
Old 10-06-17, 07:03 PM
T
Received 8 Upvotes on 7 Posts
I have a Broil King Signet 90 gas grill. The factory iron grill is all but completely rusted. I want to replace with a stainless grid but would rather not pay $160 for the factor original.
I'm looking for a 25" x 15" stainless cooking grid. Anyone know where I can get one aftermarket for a good price?
Thanks
Old 10-06-17, 08:17 PM
Received 3,884 Upvotes on 3,481 Posts
Look on amazon. I found many similar but not the same exact size. You may to opt for two smaller grilles if you want to keep the price down.
Old 10-06-17, 08:28 PM
T
My current (original) grill is made up of 2 pieces. I don't care how many pieces it is..... I'll use whatever good stainless grid I can find that fits... Just that either I can't find the right size or if I do it's like $300
Old 10-06-17, 09:05 PM
Music-City-Metals-92401-Replacement/dp/B000FN3S06
Bar-b-q-s-51022-Replacement-Stainless=25x15+stainless+steel+wire+rack
Your grill shows cast iron as original.
ereplacementparts/gridporcelain-p-801811.html
15x25 is an odd size for stainless steel. I found many cast iron replacements.
There are some slightly larger in stainless but they'll need to be cut.
Old 10-06-17, 09:08 PM
T
I need 15'x25' - Cant seem to find that in stainless... At least not for less than a kings ransom
Old 10-07-17, 05:53 AM
V
Received 3 Upvotes on 3 Posts
Here's a Sunbeam measuring 15 1/16" X 25 1/4" . . . . still too big ?
Sunbeam Gas Grills Stainless Steel Cooking Grate 15-1/16" x 25-1/4" CG-52SS | eBay
Old 10-07-17, 09:11 AM
T
Thank you! Unfortunately this seller charges a fortune to shop to canada but, now that I know what Im looking for I can just order it locally here at Sears.
Very helpful. Much appreciated
Old 10-07-17, 04:31 PM
V
If that grate would work, they're made by MHP Grill Parts, and maybe they have a retailer in Toronto ?
MHP can be called at: 847.395.6556 or emailed at: info@mhpgrills.com
Old 10-07-17, 06:03 PM
Use their on-line "find-an-authorized-dealer" portal. I put in Canada and found several listed.
STAINLESS STEEL COOKING GRID from MHP Grill Parts
Old 10-07-17, 07:43 PM
T
Yeah! I will try them. Thank you... I was looking into this and, while it does the trick.. On inspection the rods seem a bit on the narrow side. Ideally I'd like something with around 8mm steel.
I will call them this week to see if they can help me out.
