Samsung Dryer DV5451AEW XAA
My dryer is not heating, all else is working fine. Any help and or videos of what it could be would be greatly appreciated..
You posted under gas dryer but model# shows electric???? If electric you need a heater assy. Very common problem for Samsung dryers. Must of changed a hundred before I retired. After changing heater clean vent all the way to outside or you will be doing this again. Let us know if gas or electric.
There are ways to test parts before you go replacing. Check for continuity on the heater first (google search will give numerous results). If it's not that then check your thermal fuse and high limit thermostat. And make sure there are no obstructions and your vent is cleaned (cause of many thermal fuse blows).
