Stove burners low
Stove burners low
I have a Frigidaire FGFLMC55ECA Gas Stove. Recently, the burners on the range are low when several burners are on, or if other gas appliances (dryer) come on. I had the gas company come out and check the gas pressure. They isolated each appliance and all was normal. The rep pinpointed it to the stove. Today I replaced the regulator in the stove to no avail. Also, I had cleaned out each burner. Any ideas?
Welcome to the forums.
Definitely starving for gas. If you changed the regulator inside the stove..... the problem must be before there.
Is the shut off to that stove turned all the way on ?
Is this propane or natural gas ?
