Gas leak in oven valve
Old 02-16-19, 02:06 PM
Exclamation Gas leak in oven valve
Dear doiteers,
I found myself this morning with the (very literal) headache of a gas leak. Smell led me to the oven of my old stove. I removed the main pipe from the oven valve, applied soap to the valve exit, and it bubbles slowly alright. I don't ever use the oven, so I don't care for replacing the valve. So...
1. What easy ways to seal it can I do by myself? I don't mind messing the pipe in the process.
2. The pilot exit from the valve lets out A LOT of gas, is that normal? I know it has a safety valve on the igniter, and it seems to be working (no bubbles on the pilot), but shouldn't the main valve close both pipes?
Thanks in advance.
Old 02-16-19, 02:21 PM
Received 3,627 Upvotes on 3,251 Posts
Welcome to the forums.
Pretty old stove if it has a standing pilot for the oven.
Is that pilot always lit or do you have to light it when you use the oven ?
Pretty hard to comment on disconnecting/blocking off the gas valve without a make and model or some pictures..... How-to-insert-pictures
Old 02-16-19, 02:41 PM
Hi Pete,
Pretty old Caloric Heritage, yeah. Here's a pic of the valve:
Thanks for any help!
Old 02-16-19, 03:52 PM
That looked like a link for a google account. If it was.... it was set to private..... not public.
Old 02-16-19, 05:29 PM
It was just a pic, hotlinked from Google Photos with the -no-tmp.jpg trick. Perhaps they forbid that now, tho it seems to work in a different browswer. I'll upload it here anyway:
Old 02-17-19, 09:51 AM
You should be able to use flare fitting caps. The link is to show you what they look like.
The home improvement stores should carry them.
brass fittings
Old 02-17-19, 02:44 PM
Nice, I can do that myself! A pair of plugs should do the trick (the gas comes out from the pictured valve). Thanks a bunch!
