Convert Grill to Natural Gas
Trying to avoid buying a new grill, I have a char-broil performance 4 burner grill. I've been looking to convert this to natural gas after dealing with bad propane tanks (leaks when turned on at the hose connection to the tank) hassle etc. I've seen the conversion videos, looked at the manual, website, but can't see a duel fuel sticker on my grill or listed anywhere as known to be duel fuel. I looked at my grill and can take the orifices out like the videos but is something else supposed to be setup for NG (like a regulator) or is that all that needs to be done is having bigger orifice openings?
I'd have a plumber install a hookup outside and was trying to avoid another expense of a grill which together wouldn't convince me to stop lugging tanks around.
That is an inexpensive grill. Having natural gas run to the grill will likely be more expensive than the grill. If you are having trouble with leaks at the propane tank connection I would replace that hose/regulator assembly. It's probably about $30.
i have a char-broil grill and ordered a nat gas conversion it from the company earlier this year... haven't hooked it up yet. Go to their web site and enter your model, etc.
