Gas cooktop stove cutout 32 7/16" x 16 17/32"
Old 10-08-19, 10:02 AM
Need to replace existing old Sterling GCT-360 gas cooktop stove that has very small 16 17/32" depth. Countertop can't support a more traditional 19" depth cutout. Does anyone know of a source for a new or used compatible stove?.
Old 10-08-19, 06:48 PM
Received 344 Votes on 322 Posts
Welcome to the forums.
That's going to be a tough one. I spent a good while searching thru manufacturers specs. When you approach something of shallower than normal depth.... the width also gets smaller.... typically to 30".
I'd recommend checking with some local appliance stores. They have the specs in an easier to see form.
I have a feeling you may not find something in new. As far as used.... you'd need to check with used appliance stores in your area.
Old 10-09-19, 03:07 AM
Received 21 Votes on 21 Posts
Another area you may want to look at is trailer and RV places.
If you find something make sure that it can be converted to natural gas as these will be set up for propane.
