gas oven loses power while baking
Old 11-10-19, 01:11 PM
maytag MGS5770adb serial no. 331846245
Old 11-10-19, 01:16 PM
pugsl's Avatar
Received 25 Votes on 24 Posts
What is oven doing losing power makes no sense.
Old 11-10-19, 01:18 PM
Received 416 Votes on 389 Posts
Welcome to the forums.
Loses power while baking.
Does the display go black ?
Does the temp show correctly but heat is low ?
Please explain in detail.
Old 11-10-19, 01:26 PM
Norm201's Avatar
Received 91 Votes on 83 Posts
Do you get an F4 code?_________________________________
Old 11-11-19, 06:21 AM
clock goes out and heating stops. like it lost power. clock comes back on after it cools and flashes. reset clock and start over.
Old 11-11-19, 06:06 PM
I posted a wiring diagram for you. Parts mentioned circled in red.
When this happens..... do the stove top burners still light and does the oven light still work ?
If yes..... there is a thermal limiter in that range that cuts power to the control section on overheat. It's surprising to be overheating in general baking.
Are you running the oven up high temps ?
You may need to check and see if the cooling fan has a problem. I'm not exactly sure when it runs and in which modes.
In the following link...... "01-Body". Part 15 is the fan and part 20 is the thermal switch.
Exploded parts views
