GE GAS DRYER
Old 06-04-01, 09:22 AM
Guest
Question
I NEED HELP INSTALLING A FRONT DRUM SEAL. CAN SOMEONE HELP ME INSTALL THIS SEAL. MY DRYER IS NOISY WHEN OPERATING AND IS DRIVING MY WIFE AND I CRAZY (IF YOU KNOW WHAT I MEAN).
[Edited by RussFernandez on 06-04-01 at 12:53]
Old 06-04-01, 06:19 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Arrow Roller Bearings...Slider or Glider Pads...Drum Bearing
Hello and Welcome RussFernandez to the Do It Yourself Web Site and thanks for posting a question in my Gas Appliance forum.
The noise may not be coming from only one worn out part. Therefore, I suggest you open up the dryers cabinet, top and remove the front panel and look for signs of worn out parts mentioned above.
Best suggestion is to write down make, model and serial number and visit the local appliance retail parts store. There you can get the required parts and installation instructions.
I also suggest you replace all parts and the belt too,that the drum rotates on, while the dryer is opened up and under repairs. Also clean out all lint inside the cabinet and clean out the entire exhaust system while your at it.
Regards & Good Luck
Forum Moderator
Tom_Bartco
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
