1958 Tappan range oven valve problem
This range is at my cottage and gets infrequent use. The gas valves were getting stiff to operate, but did the job.
Yesterday I muscled the oven valve on and there was a "crunch", then the valve rotated more easily. I knew this wasn't a good thing.
Now the oven temp is 100* lower than the knob indication. Knob still rotates thru it's normal range & turns off correctly.
What gave out, is it repairable?
Unfortunately gas valves were never designed to be serviced. It's possible the valve could be replaced. A model number would be helpful.
I corrected the title.
I wasn't able to locate a replacement gas thermostat.
That doesn't mean there isn't one available just that it may not be a "drop-in" ready part.
Stove parts
Stove parts
You may want to consider having that thermostat rebuilt.
Check with this company......... Repco rebuilders
Stove parts
Stove parts
Thank you!
I've written Repco for a quote.
I've never removed the top on this range. I don't see any screws under the front, or along the sides. Is it held on only at the back?
I can't help you there.
Take the knobs off and check in there.
Any screws under the front knob plate and just above the door ?
Is there a gap on the sides approx 3" down ?
