Another weird range igniter troubleshooting mystery
Hi, I have an 20-year-old GE Monogram Range, and I'm not sure where the problem I'm having lies. Here's what's been happening for about a month now:
So, three igniters seem to have lost the ability to sense the flame. I'm leaning toward either some wiring along the way is flaky (maybe mice?!), or there's a ground issue at each of the burners??? Also note, some of the screws holding the burners down are rusty and so i can't reseat the burners to try and fix some grounding issue without a lot of trouble. I was thinking of swapping the wiring on switches/electrodes into the module to see what might change, but I figured I should ask first, it might be totally obvious.
So, any advice on what thing is definitely bad, or a sequence of troubleshooting would be appreciated! Thanks in advance!
- * Sparking WHEN NOT LIT: Ticking happens constantly when not being used. (I just turn off the breaker unless we're cooking). Nothing is wet or greasy, I've cleaned it all up nice.
- * ALL ELECTRODES appear to WORK: All burners can be lit by their respective igniter electrodes. The spark on all igniter electrodes looks like the same “level”/”quality” of spark to me.
- * Three of four burners don't stop the sparking WHEN LIT: Only one of the burners stops the ticking when lit. The other three light, but ticking persists. One more thing to note: I'm 99% sure it's the FIRST burner switch on the harness / first igniter named on the module if that means anything. (I have a schematic, but it's a bit newer and I didn't tear the stove apart again to check the wiring yet.)
The module always sparking could be a defective module or one of the switches on the burner knobs is shorted. The fact that the other burners don't shut off when lit would point to a defective spark module.
Please post the model number from your appliance.
I can't find much technical info on that model.
Can you double check the posted model number for me ?
Is that a five burner range ?
It’s four burner and griddle. I found the repair manual/schematic online and noticed it was for a newer version. Specifically I opened it up and can’t locate the reigniter module in the top, front, or bottom.
I think the 2 should be omitted, so:
ZDP36N4DWSS
thanks!
ZDP36N4DWSS
thanks!
Found the reigniter, in the top under the burners. Checked the ignition switches and some have continuity while not only in the light position, so I read that means they are bad. But I think the module is bad too. Found 6540S0001 module that looks identical and has same specs.
