Roper Dryer timer knob does not move
Old 06-24-01, 06:20 PM
chicfrelix
Question
My Roper dryer timer knob(switch) does not move once it's set. The unit turns on and everything appears to be fine except for the fact that it never turns itself off and it doesn't provide heat. The gas line and air vent checked out ok.
Could the timer defect stop the heat flow? And what is a fair price to pay for a new timer switch? Thanks
Old 06-24-01, 07:59 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Glow Coil and or Solenoids
Hello chicfrelix
The fact that the timer does not turn may not be the true cause of the problem. Although suspectable, I would recommend you determine why the dryer isn't heating.
The timer will not advance if the glow coil is burned out. You'll have to watch the glow coil to see if it glows. If not, it could be burned out.
If it glows but the burner doesn't light and the coil goes out, it could be the solenoids are defective. Which again rules out the timer.
The timer will remain at the starting point you set it at until the heat drys out enough moisture from the clothes. Without the heat that won't happen and therefore the timer will remain at the setting point.
Below is a list of possibilities that may or may not apply.
Pick and choose what applies to the dryers current condition.
Other items you may need to do or want to check/do {whichever applies} while your in the process of repairing the dryer. Pick and choose as needed.
Restricted Exhaust Vent: {Clear as needed}
Check the entire system. This also includes the exhaust vent hood outside. It has a flapper that may not be opening fully or not at all. Locate any restriction within the entire exhaust system and clean out all lint. Replace exhaust vent tubing as needed.
Defective Solenoids: {If applies}
There are two...both are on top of the gas valve.
You'll need to either remove them from the top of the gas valve or remove the entire gas valve assembly first. Take them or the entire unit to your local appliance parts store for testing. Solenoids also supply voltage to the glow coil and are part of the electrical loop.
Defective Gas Valve: {If applies}
Remove entire unit as an assembly. Take the entire unit to your local appliance parts store for testing. Gas valves are not repairable. Replacement is the only option.
CAUTION: Do Not attempt to repair the gas valve! This is a non repairable item!
Defective Glow Coil: {If applies}
It's a rare possibility but worth noting here. The glow coil may just be too weak to allow current to continue to flow to the coils. The solenoid coils are also part of the electrical loop and may effect proper glow coil operation or functioning.
Timer: {If applies}
Control center for all functions. If the timer or any other selection switch, on the front control panel, is suspected of causing the current problem your having with the appliance, be sure all selections are correctly set. If they are, the timer or other function selected switch may be defective. Any or all of them can be removed and taken to the local appliance retail parts store for testing.
Safety Reminder: {Always applies}
ALWAYS be positive you have unplugged the electrical power and turned off the gas supply to the appliance prior to attempting any repairs!
Check the archives, within this forum, for other postings on this topic and also for cleaning the exhaust venting system for further information.
Forum Moderator
Tom_Bartco
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician....At Your Service....
