GE Monogram range igniter won't stop clicking
Old 08-15-22, 12:49 PM
C
Arrow GE Monogram range igniter won't stop clicking
I have a GE Monogram range model#ZR90301P that the igniter won't stop clicking in off position but is off when turned on. I've cleaned as directed on the Internet and still clicking. red light on knob stays on while in the off position and clicks. could this be from a faulty ignition at the knob or whole module?
Old 08-15-22, 08:15 PM
Received 3,610 Upvotes on 3,236 Posts
Welcome to the forums.
That is not a valid or complete model number.
If the igniters spark when all the knobs are turned off.... it's caused by a defective spark module or liquid in the burner control. Since one of your burners is showing active when it's turned off.... that would indicate a problem burner control. It could still be water/liquid got into the control.
Old 08-16-22, 09:41 PM
C
Thank you PJMAX for the reply. Sorry I got the serial number the model number number mixed up. the model number is ZGP366N N1SS. I'll look at both module and burner control. Thank you for pointing me in the right direction.
Old 08-17-22, 10:35 AM
The circuit is fairly basic. Power (red) is supplied to a switch on each burner control. When turned on it supplies power to the LED and the spark module. In order to make the LED come on or the spark module to operate requires one of the switches to close. If you have an LED on.... that would be the burner switch you'd need to check. There is a tech sheet pdf posted below.
GE Monogram ZGP tech sheet posted for a limited time. Tech sheets available on request.
Old 08-30-22, 05:51 PM
C
Thank you PJMAX for the info. I finally got around to fixing it and all I had to order was the Harness Burner Box PART# WB24K10086. Now there's no more clicking
Old 08-30-22, 06:08 PM
Good job. You're welcome.
