Brass fittings for gas dryer
Old 07-28-01, 04:04 PM
Guest
Should I use teflon tape when making a brass to brass connection? If I do, will that make a leak?
Old 07-28-01, 08:45 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
I Don't Recommend It!
Hello groovy989 and Welcome to the Do It Yourself Web Site and my Gas Appliance forum.
On pipe to pipe thread fittings it's okay if done correctly. Done incorrectly a leak may develope.
However, pipe thread compound, plain motor oil or grease work best. I suggest avoiding the use of pipe tape.
Tip:
When using tape, make only a single warp around the threads. More then one wrap and a leak may develope.
Regards & Good Luck
Forum Moderator
Tom_Bartco
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
