self cleaning oven door won't open
Old 01-01-02, 04:57 AM
G
Guest
Unhappy self cleaning oven door won't open
After cleaning my signature 2000 tappan self cleaning oven, the door will not unlock. The bar slides all the way to the left and the oven door seems to unlock, but the lock will not disingage enough to let the door open.
I've tried to release it by prying and sliding wire, but have had no results.
Please forward any ideas.
[email protected]
Old 01-01-02, 05:52 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello Wanda. Welcome to my Gas Appliances forum and our Do-It-Yourself Web Site.
Sorry. I do not reply to private email address's. The idea is to answer all questions within this forums topic, to allow others reading the topic, to also learn from all replies posted.
The problem your oven is having is an all to commonly occurring problem with the self-cleaning functions.
Possible solutions are listed below.
Use those that apply to the existing condition your having.
Try removing the electric cord from the wall socket. Leave the oven and or entire stove unplugged for several hours before plugging it back into the electric power. By doing so, this may release the locking device.
If that fails, once again unplug the appliance, try using a thin blade knife or screw driver to release the lock by entering through the latch lever space between the door and the ovens outer frame.
If this method fails, you may have to remove the entire glass front panel and access the locking device from inside the cabinet.
Before attempting any repairs, first, check ALL the function control settings, on the front panel. Doing this is only to verify that all control selections are set correctly.
Try every optional setting possible, in an attempt to verify that no optional selection, setting and or condition has been overlooked which may be possibly causing the problem.
If all the above is determined to be accurately and correctly set, most likely the micro switch, in the door locking mechanism, which activates the self-clean cycle is stuck, even though the lever is released and the door opens.
What your likely going to need to do is remove a cover plate or panel which covers the locking device, in the ovens door frame {not in the door} and attempt to manually release the locking device and or tiny micro switch.
CAUTION:
Be careful doing this. The appliance must NOT be plugged into the electrical power source!!!!
If it is not possible to determined exactly how to release the mechanical locking device, removing the wires attached to the tiny micro switch may be necessary. If you do remove the wires, be sure to use electrical tape to wrap the wire terminal ends to prevent any possible electrical shorts or electrical groundings.
Should the wires need to be removed and it does solve the problem, you then have two other choices. Leave the wires unattached, reassemble the access part or parts removed and continue to use the oven without using the self-cleaning cycle again.
Have that self-cleaning function fixed by a service professional when some other operational function fails and a service representative is needed to correct that condition. In this manner, two inoperative conditions can be corrected with one in home service call.
Suggestions:
Read the manufacturers online web site for product information, problem solving methods, disassembly instructions, repair proceedures, pictorials and schematics, may be available online.
Suggestions:
Read the manufacturers online web site for product information, problem solving methods, disassembly, reassembly methods, repair proceedures and instructions, pictorials and schematics, which may be available online.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers if you stop in at the store.
Read any current and ARCHIVED questions on your topic, within this forum, for other postings and the REPLIES offered.
Regards & Good Luck
Gas Appliances Forum Moderator
Tom_Bart........Fast, Fair, Friendly & Highly Efficient......
TCB4U2B2B.....Company Enterprises.
Energy Conservation Consultant & Natural Gas Appliance Problem Diagnostics Technician.
Old 01-01-02, 06:02 AM
G
Guest
locked self cleaning oven door (gas)
Thanks for the info...Sorry I did not note it is a Gas stove. I will try removing the glass. All knobs are in the correct position.
Old 01-01-02, 05:10 PM
W
wonderskink
Most common cause of this problem is that the locking arm has gotten bent.
To restore it to it's original position, put unit into a self clean cycle. Then push the locking handle all the way to the right as far as it will go. Then push it about 2" further, bending the handle to the right. NOW you can move the handle to the left and it will open the door.
Old 01-02-02, 03:52 AM
G
Guest
oven door opened
THANK-YOU WONDERLINK
It worked great! Now we can have pizza for lunch!!!
