Dryer Won't Heat
Old 02-24-02, 01:45 PM
gcollis
GE Gar Dryer Won't Heat
I have a GE Gas Dryer that will not heat
Old 02-24-02, 07:34 PM
A
Need more info,motor not turning ,won't start,etc.etc.make model year.theres qiute afew things that can stop a dryer from heating.
Old 02-24-02, 08:00 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Question ....More Detailed Information Requested
Hello G. Collis. Welcome to my Gas Appliances forum and our Do-It-Yourself Web Site.
Kindly provide more detailed information about the exact problem with the dryer. In depth and detailed information regarding the problem with the dryer helps to explain the situation your dealing with in a manner that allows myself and or other professionals to offer the best possible helpful solutions, suggestions and professional advice.
Also provide the units brand name, year, model, serial numbers, if available, type of ignition system and the location of the dryer. Please include details regarding any recent repairs made, if applicable.
Any and all additional detailed information you can provide may help to expose a clue regarding the current problem and help to determine the exact repair to correct the condition.
Your assistance in this matter would be both appreciated and beneficial.
To add more information, please use the REPLY button. By doing so, the additional information you add will remain within this posting {Thread} and allow the forum readers to follow the topic.
Suggestions:
Read the manufacturers online web site for product information, problem solving methods, disassembly, reassembly methods, repair proceedures and instructions, pictorials and schematics, which may be available online.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers if you stop in at the store.
Check the recent postings and ARCHIVES, within this forum, for other postings on your topic, specific appliances problem or conditions and read the replies offered. Chances are the topic, condition and or problem has already been covered in complete detail.
Regards & Thanks
Gas Appliances Forum Moderator
Tom_Bart....Company Enterprises.....TCB4U2B2B
Energy Conservation Consultant & Natural Gas Appliance Diagnostics Technician.
Old 02-25-02, 07:56 AM
gcollis
more info
the motor runs, air is forced out the vent, the tumbler turns, the timer works as far as I can tell, just no heat.
Old 02-25-02, 07:38 PM
Admin Emeritus
Arrow Glow Coil
Hello: gcollis
First item to check is the glow coil. Open the burner access door and then turn the dryer on. Watch inside the burner compartment for the glow coil to light up and glow.
If all the controls are set correctly on the front control panel and the dryer is running but the glow coil fails to glow, you located the defective part. The glow coil will need to be replaced.
To remove the coil, turn off the gas first. Unplug the dryer from the electrical wall plug. Then remove the entire gas valve as an assembly. Take the entire assembled part to the local appliance retail parts store for a replacement coil.
Appliance parts dealers test and carry replacement parts for all appliances. Parts dealers are listed in the phone book under appliances.
Should you require additional help and or want to post any additional updated information, kindly use the REPLY button.
Regards & Good Luck
Tom_Bart........"Fast, Fair, Friendly & Highly Proficient"......
TCB4U2B2B.....Company Enterprises.
Energy Conservation Consulting Services & Gas Appliance Problem Diagnostics Technician Services.
