hooking up gas range
Old 02-25-02, 09:51 AM
legemeaux
Question hooking up gas range
I am going to hook up my gas range (Fridgidare) myself. I have the connectors and flex, but have two concerns. The pipe coming out of the floor is gold in color, has a male connector already on it that does not look like it comes off, and there is some paint on the rim of said connector from when the original owners of the house painted the walls and did not cover the pipe. 1) Is the paint on the edge going to cause any problems with sealing? 2) Is this pipe okay to connect to? Have only had the house for one month, don't want to blow it up yet .
Thanks for your help.
Old 02-25-02, 07:26 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Question More Information Requested
Welcome legemeaux to my Gas Appliances forum and the Do-It-Yourself Web Site.
I'm not totally sure but I think the gold colored pipe may be the adaptor from the old appliance connector left on the pipe. The old connector may still be connected to the adaptor, if I understand your description.
The questions to you are:
Is this a USA installation?...YES or NO?
Is the gas supply pipe iron or steel?
Is the old stove still connected?...YES or NO?
Is there a shutoff valve on the iron or steel pipe? YES or NO?
The paint on the connector nut or adaptor can be removed with a wire brush.
Since I asked you questions and you need to reply back, use the REPLY button. By doing so, the additional information you add will remain within this posting {Thread} and allow the other readers of this topic to follow the topic and allow me to post any further helpful advice and suggestions.
Regards & Good Luck
Gas Appliances Forum Moderator
Tom_Bart........"Fast, Fair, Friendly & Highly Proficient"......
TCB4U2B2B.....Company Enterprises.
Energy Conservation Consulting Services & Gas Appliance Problem Diagnostics Technician Services.
Old 02-26-02, 05:24 AM
legemeaux
Tom,
Here are the answers:
Is the gas supply pipe iron or steel? Iron I think
Is the old stove still connected?...NO
I also don't know if any paint got inside the pipe. Is that a concern?
Thought this would be pretty simple, but starting reading "how-to's" and they start to make you worry (are all "how-to's" written by installation professionals who want you to freak out and just hire them )
Thanks
