Dryer does not turn, but does heat up
Our gas dryer suddenly stopped turning. It does heat and make a close to normal sound, as though it were drying as usual.... But if you open it, it has obviously not been turning.
I have not worked on dryers before, but have heard this could be a belt problem?
Any pointers or insight? If it is a belt, is this usually a simple repair, and what is the average cost?
Thanks in advance!
Thanks in advance!
Hello,
If the motor is running and you have heat with no drum movement...could very well be a broken drum belt.
Pointers and insight:
Loads linked here
Depending on age, model, belt...most are not difficult to replace
Average cost?...of the belt?...or the whole job if you call someone?
Belts can vary from 10-50 dollars....the whole job...service call, labour, belt...average 75-100 dollars.
Hope this helps,
jeff.
p.s. Green for St. Paddy day
Loads linked here
Hope this helps,
jeff.
Received 7 Upvotes
Hello: Jeff Placzek
Check the control panel selections. Some dryer models have a "NO TUMBLE" selection. This selection is used to dry items that should not be tossed around etc. Tennis Shoes would be a perfect example.
And there you have it..."My Two Cents Worth"...
Regards & Good Luck
Gas Appliances Forum Moderator
TCB4U2B2B.....Company Enterprises
Energy Conservation Consulting Services & Gas Appliance Problem Diagnostics Technician.
Note To Jeff1
I like the GREEN print...LOL
You have a PM or 2 awaiting. RSVP-ASAP
TomB
Regards & Good Luck
Note To Jeff1
TomB
