Smelling gas when igniting stove
Old 05-27-02, 08:55 AM
bproch
Question Smelling gas when igniting stove
This may be a silly question but Im not sure who to ask.
We moved into our house about 2 years ago. There is a Caloric gas range (electronic igintion)...it always clicks 4 times or so, then before the flame starts.
Is it normal to smell gas during that time? IM pregnant and I guess Ive never noticed the smell before...Im wondering if Im smelling it now because of my heightened senses....
I just want make sure everything is ok. It never smells like gas when it is not in use....it just smells when I first ignite it...is this normal?
Thank you.
Old 05-27-02, 10:11 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Upvotes on 4 Posts
Hello B Proch and Welcome to our Do It Yourself Web Site and my Gas Appliances forum.
The situation your describing is not all that uncommon. The small amount of gas smell between the time it takes to ignite a top burner from the time the valve is opened is normal.
The tiny amount of gas is not toxic nor harmful. The kitchen area is much too large to cause problems for that tiny amount of gas.
FYI:
Natural gas does not poison a person. In a large quanity in a closed contained enviroment, it can and will suffocate a person simply because it absorbs the oxygen in an enclosed area.
In the FYI case noted above, only when the air to fuel mixture is between 10% to approzimately 22% can gas explode. Trior to this, suffocation is likely to happen.
Back to your topic question. To help ensure quicker igniton, clean the ignition ports {Tiny Holes} up the sides of the burner heads but do not enlarge them. A pin can be used or a thin piece of wire.
Read the RECENT postings & ARCHIVES, within this forum, for other postings on this topic and the replies offered.
If you need further assistance, use the REPLY button. By doing so, the additional information you add or questions you may have, will remain within this posting. Using this method also moves the topic back up to the top of the list automatically.
Regards & Good Luck both with the stove problem and the pregnancy...
Gas Appliances Forum Moderator
Tom_Bart........"Fast, Fair, Friendly & Highly Proficient"......
TCB4U2B2B.....Company Enterprises.
Energy Conservation Consulting Services & Gas Appliance Problem Diagnostics and Technician Services.
