Oven Thermostat Question
Old 06-21-02, 01:11 PM
ronko
oven thermostat control
Having trouble finding a oven thermostat control
for Chambers model PC-1000-E, Serial number 90021H8B. Numbers on back of part is 512-223 or B6761 D 76
Old 06-21-02, 02:34 PM
Sharp Advice's Avatar
Admin Emeritus
Received 7 Upvotes on 6 Posts
Hello: ronko
Lots of helpful information can be found on this topic. It's all located within a prior posting on oven thermostats. Check back a few days prior for the posting.
If the local dealer does not have the exact thermostat replacement, the thermostat may still have a replacement offered by another manufacturer.
In order to locate the part or it's replacement, you may have to search out other resources, as explained in that prior post and several others, within this forum.
Regards & Good Luck
Gas Appliances Forum Moderator
Tom_Bart........"Fast, Fair, Friendly & Highly Proficient"......
TCB4U2B2B.....Company Enterprises.
Energy Conservation Consulting Services & Gas Appliance Problem Diagnostics and Technician Services.
