Jenn Air Range problems
I have a Jenn-Air Gas Range w/convection. We have had it for 2.5 years now and we love it. Today we had 2 problems (the 2nd came from trying to check the 1st problem - my fault):
1. Smelled gas and oven took way too long to heat, so we checked the bottom burner. The flame on the burner keeps pulsing on and off, instead of staying on steady. Is this normal? If not, any suggestions?
2. When we put the range back together we got an f9 code which is "check door lock circuit." Can't find anything that explains how to fix this. The code came on 2x, we re-adjusted the door and it seems to have gone away.
Thanks for any help - great website.
Larry
Larry
Received 5 Upvotes
Hello lkahn and Welcome to our Do It Yourself Web Site and my Gas Appliances forum.
The possible causes of the problem your describing and the possible answers to your question on the ovens operating condition, are posted within a similar question posted 06/03.
Reading that posting should offer you some insights on the possible causes of the problem and correction methods.
Suggestions:
Read the manufacturers online web site for product information, problem possibilities, causes and solving methods, part locations, disassembly, reassembly methods, repair proceedures, and instructions, pictorials and schematics, which may be available online.
An excellent source for orginal replacement parts is your local retail appliance parts store. Appliance parts dealers test parts and carry replacement parts for all appliances. Parts dealers are listed in the phone book under appliances.
Retail parts dealers can also help determine what the possible problem may be. Bring the make, model and serial numbers and stop in at the store. The info will help to determine the possible problem causes.
If you need further assistance, use the REPLY button. By doing so, the additional information you add or questions you may have, will remain within this posting. Using this method also moves the topic back up to the top of the list automatically.
Regards & Good Luck
Gas Appliances Forum Moderator
Tom_Bart........"Fast, Fair, Friendly & Highly Proficient"......
TCB4U2B2B.....Company Enterprises.
Energy Conservation Consulting Services & Gas Appliance Problem Diagnostics and Technician Services.
Suggestions:
Regards & Good Luck
