central air problems
we have central air. i came home fromwork and it wasnt working at all. i turned it off and on and it wouldnt kick on at all. the fan or nothing will kick on. i checked the breaker box, nothning was wrong there. the thermostat semms fine also, it ha the right time,date and temperature we have it set at. please tell me what i could do!
Check the breakers again. Turn them off then on. If that's ok, then turn power off to both the indoor and outdoor sections. Take the thermostat off the wall and make a sketch of which color wire goes to which terminal. Remove the wires and twist together the bare copper ends of the wires from R, G and Y terminals. Now, turn the power to the indoor and outdoor units back on and see what happens. This will tell us if the thermostat is the problem or if we need to dig deeper.
