oiling outside ac unit
Old 08-13-02, 10:53 AM
Huxley
will 3 in 1 oil work to oil the motor?
Old 08-13-02, 12:53 PM
E
Although I prefer Zoom-Spout, 3-in-1 should be fine for the condensor fan motor (use the red can, not the blue can, which is thicker oil for larger motors). Make sure you oil both ports, and don't overdo it -- a few drops in each port should be enough. Also make sure you don't bend the blades in the process.
