Gas furnance maintanance
Old 08-19-02, 02:50 PM
1
We moved to our new house 4months back. Forced air Gas furnance is about 15 to 20 yrs old and works fine.
How to maintain it? How to change or replace filter? What types of filters available?
We do not any manuals for it.
Also, is it better to replace the current furnance with new one for efficiency even though it works fine?
Thanks.
Old 08-19-02, 03:02 PM
hvac4u's Avatar
replacement
would be a good idea if you are planning to be there for several years. a new furnace would pay you back in efficiency and reliability. your filter is possibly located in the blower compartment of the furnace, or near the return air inlet. some are located in the return grille itself. types of filters vary with efficiency. a pleated one inch filter would probably be the best bet, check local hd or lowes for various efficiencies. if anyone has allergies, you may want to go with a higher efficiency filter, spaceguard or airbear/trion, etc. maintenance wise, check the burner assy for rust, shine a light into the heat exchanger (where the flames burn) and look for cracks or holes. if you find some replace the furnace. check the motor for oil ports, it may not be permanently sealed, and may take oil.
Old 08-21-02, 07:05 PM
1
Question More questions
Thanks for replying.
More Questions:
1. On the duct (On top of blower) there is on/off switch. What is this for? Is it going to turn on/off the gas or furnance?
2. The filter on the return duct has also on/off switch for cleaning.
Is this automatic cleaning filter? It was turned off when we moved in. Should I turn this on for cleaning filter? For How long?
Also, do I need to shut off furnace when I do this?
Old 08-22-02, 08:14 PM
hvac4u's Avatar
switches
the top one probably is power to the furnace, and the one at the filter is more than likely powering an electronic air cleaner. these switches should be on for operation, and off for maintenance.
