capping a gas pipe?
capping a gas pipe?
Hello
i need to remove and cap a gas pipe for
later use... can i buy a cap for this pipe?
and if i can.. do i have to seal it with something? (the cap)
You just install a cap if it is a nipple. If it is a line, say into a kitchen or wherever, and there is no valve; you need to install a valve (turn it off) and then plug the valve.
Use pipe dope on joints and be sure to soap test every joint after you are done.
