HVAC System Inoperative
Old 09-02-02, 09:31 AM
prevo1117
Angry Flashing light
I have a Arcoaire force air up draft. The led on the control box
flashes and the unit will not start. if light is flashing refer to
service instrctions.I have no service instructions.
======Moderators Note======
Hello: prevo1117
I moved your topic here. Based upon the subject, I suspect it pertains to an electric {Heat Pump} heating and or cooling appliance.
Old 09-02-02, 12:33 PM
hvac4u's Avatar
look on the board
itself that contains the flashing light, there should be a code, if not look on the door or blower assembly, the flash code should be there. what is the model #, and how old? check for a fuse on the board, similar to a car fuse, it may be blown. check low voltage wire going outside for weedeater, etc damage.
