central air unit
Old 09-10-02, 04:35 AM
wtrpar3
central air unit
I'm hoping I don't have big trouble. I have found water on my kitchen floor and have discovered it is coming from my furnace when the central air is on. It is running out from what looks like a vent? on the unit. What could be causing this?
Old 09-10-02, 10:50 AM
hvac4u's Avatar
find the drain
and be sure it is clear. if you cut the drain and water pours out, the drain is clogged, if not, your pan may be rusted through
