HVAC coil replacement
How much should I expect to pay for complete replacement of the A-coil in my HVAC unit. The unit services an 1750sq' condo, not sure on units spec and all though?
Re: HVAC coil replacement
Need more infornation. Exterior coil, interior coil. I don';t know if this forum allows price quotes.
many factors involved
tonnage (capacity), metering device (expansion valve or fixed), location (easier access, lower price), where you liuve (i can only refrence my location) and time of year. not trying to confuse you, but rather explain why you could get many different figures on this forum. i assume you are referring to the evap coil, on the inside of the house. in atlanta a standard evap coil replacement withe fixed metering roughly 2 to 3 ton (which i assume you have) upflow configuration, would run $500 to $750, this is ball park only. if this is an airhandler for a heat pump, much higher, as you may consider replacing the airhandler itself. call several companiers in your area, quotes are free.
