reset tripped
Old 09-23-02, 04:04 PM
JRRR.
reset tripped
The reset on my furnace tripped 2x in the last two days. I just had a tune up on it and the transformer changed. Can anyone give me some reasons. It is hot water heat. The burner is a Beckett. Thank you in advance.
Old 09-23-02, 08:25 PM
Nominal
Jrrr, if you just had it serviced, then call them back. It is probably something simple, like electrodes set wrong, or photocell weak. Also something else could be wrong that he didn't catch or is difficult to catch, like checkvalves in pump not holding, therefore pump could be loosing prime over a period of time. Also make sure the filter and nozzle were changed. An oil furnance is a fire danger for the average do-it-yourselfer. I would suggest calling the company back again.
